Florida MV Owners
ApopkaFL
Banned
596
Middlesboro KY
I am in a pickle, My in the A3 build. I thought I had the correct U bolt / plates but I found out today they are for the REAR. I am in need for some FRONT U-bolt plates. I am in Winter Haven FL, anyone close to me have any that I can buy? The rear axle is ready to go in but I need those plates..... I have the top that the U-blots hang over.
Rodman
A
A/C Cages
Guest
I wish I could help you out, But I gave everything I had to Grant.
PM Grant at GulfStreamDriver on here. I know he has most everything over there in Sebastion FL.. Thats not too far away.
Hope that helps??
A
A/C Cages
Guest
I just spoke to Grant, sorry he doesnt have one. But I will keep my eyes out for both of you.
1,176
I only have A2 parts....
1,176
Have you tried GreenGem? MAtt was at the Fla rally(when I was there) selling stuff. I think he parts trucks often.
1,176
Are you going to cut off the top of those, so they don't hit the frame?
Tow4
640
Orlando, FL
Yeah, cut the ears off and put a snubber on. I doubt you will load it enough to bottom out, but it might hit if you get it cocked off roading.
gringeltaube
Staff Member
2,477
Montevideo/Uruguay
Yes, to wide! U-bolts spread to far apart at the top, and not pulling perpendicular to the lower plate, => asking for trouble.
Get the correct ones!
G.
gringeltaube
Staff Member
2,477
Montevideo/Uruguay
Hey, don't discard those U-bolts. You have a torch; red-hot, that material can easily be bent to conform the more squared shape required for the front spring saddle. When done just let them cool down slowly.
G.
A
A/C Cages
Guest
Ive seen someone try to use heated copper tubing, sliding it over the whole ubolt exept for the threads... Within about 3 years of offroading, he finally had to change them out.
Redneck repairs. But it worked!!!
