Copout911
- 12
- 3
- Pearisburg, Va
Good Moring all, New (ish) here,
I recently purchased an FLU 419 that has been sitting for years, How Many is undetermined. The first few things I did was do a fluid check and all seemed ok. I then installed fresh charged batteries to start it. After troubleshooting the start button finding a bad relay just located by the fuse clusters. I then got the engine to start with a bump of ether and it seems to bust right off but at very high RPMs and would die if you didn't stay 3/4 to wide open throttle. It did seem underpowered and would fall off not idle down. an interesting observation is that I could rev it up and down between 1600 RPM and 2500 RPM with the foot peddle and sometimes it would return and sometimes not, it would stay at high revs. The linkage to the hand lever and foot peddle have been lubed/checked all the way to the injection pump and is free to move and return. While I do work/play with many types of engines but learn from all and don't know it all. My thought is this engine wouldn't run starving for fuel, but I cleaned/checked the prefilter screen to find nothing of consequence as well as checked/cleaned the two cartridge filters again with nothing notable, i also drained and put new clean diesel in the tank. After priming I get the exact same results. I would love for someone who has experienced this prior to chime in with a fix as it seems this is a common issue as posted by several people but non offered the solution as happens a lot after one's problems are fixed. Please offer and ideas from experiences of your own.
