FLU419 HMMH Forklift not lifting weight
LogdeC66
Canton, Georgia
Cheers all,
I am having issues with my HMMH forklift not being able to lift anything over perhaps 500lbs. I know that it is controlled hydraulically via the forward (left) cell. No obvious leaks or line damage. It just buries itself in the front end when attempting to lift up a pallet. Has anyone experienced this issue before?
Thanks!
The FLU farm
1,302
The actual midwest, NM.
Thankfully, I have not experienced anything like that yet. Mine lifts well over the 4,000 lbs. it's rated capacity, and my only complaint is that the side tilt cylinder could use a restrictor - or I need to become a better operator.
I'd start with checking the belt tension, then if the valves look/act happy. You say that the hoses and lines are good, but I'd still look for any potential issues there, too. Does the lever move freely throughout its entire range?
Of course, I'm taking for granted that you have the correct amount of proper fluid in the tank. Do you?
Good luck, and let us know what you find.
