Fluid on rotors
TLangM998
Buford, GA
Newbie here! Just wanted to get your guys' take on this before I started taking things apart. Removed my front passenger side half shaft to replace a torn boot, and discovered this... Any ideas on what to look at first?
NDT
6,156
Camp Wood/LC, TX
Could be GO90 from the diff or BFS from the caliper. Mostly looks like GO90 that oozed past the flange splines and was trapped by the halfshaft, and ran down when you pulled it.
86humv
493
Texas
Replace the Star like seal behind the nut of the stub shaft.
papakb
1,186
San Jose, Ca
Just give it a good sniff. If it smells like sulfur it's gear oil. Silicon brake fluid has almost no smell at all.
Retiredwarhorses
4,054
Brentwood, Calif
That’s gear oil, remove the nut on the flange and remove the old star rubber seal and install a new one, this is a common issue. Before the star seal, they used multiple o-rings and they were prone to failure and seapage.
