On the t case on the back you have 2 big bolts top is fill bottom is drain. It takes dextron same as a th400. Fill it back up till you can feel fluid between the first and second knuckle
This is a picture of a 208 with no fill or drain plugs they are out there this on is in a 1009![]()
Huh? I can see both of them.This is a picture of a 208 with no fill or drain plugs they are out there this on is in a 1009![]()
