Domterry12
- 53
- 18
- New Jersey
Ok fellas and felletes, here’s the mystery. I’ll start from the beginning….
I bought this m1009 roughly 2 years ago. I bought it and pretty much immediately lifted it and put 35” tires on it. (I know, blasphemy). Before lifting I had test driven, driven around block a couple times, and everything was fine. Right after lifting, backing out of the garage. I had a knock in reverse. I panicked lol. But soon realized something was knocking the flywheel inspection cover because removed cover and noise was gone. I put it back on spaced with washers And was good. Chalked it up to something with angle of lift or something. Few months later came back, spaced with 3 washers each hole. Went away again. Came back removed cover completely.
Well now it’s back again, even with no cover. I changed the harmonic balancer cuz j had a slight wobble on crank pulley and also seems slight wobble at flywheel/converter.
I was inspecting today and it seems the weight (brake pad looking thing) on flywheel has scrapes and it could be contacting there. I sprayed some paint on it this morning to see if it scrapes off but haven’t had a chance to drive the truck.
Is the weight on the flywheel supposed to face the front side of the truck? I read in another thread it’s supposed to face the rear, that can be my problem if it’s true.
starter looks original and untouched, but I’ve read a lot about it being shimmed and maybe it’s not shunned far enough away?
Im lost, truck runs perfect, has great power, I can’t see it having a broken crank running so smooth. And the knock is not coming from oil pan area i listened with a stethoscope. My ideas are unbolt converter, push it in and run, see if change. Hard to remove starter or fly wheel and then run it LOL,
can the cucv gods please help? @cucvrus @Warthog234 I know you guys know your stuff.
