Upon replacing the clutch and trans in my M35, I noticed one of the clutch pressure plate mounting holes on the flywheel was stripped out. I was going to heli-coil this hole but noticed there is a shoulder on the pressure plate bolts. If I was to heli coil this, the bolt would not fit in the flywheel snug. I ended up finding a "good" flywheel to use. It seems that the pressure plate bolts get stretched quite a bit, has anyone else ran into this problem ot seen this?
Thanks, Matt
Thanks, Matt
