FMTV 2” hitch
xomegaiv
Yuma, AZ
Not sure if anybody has done this. We needed to pull a normal (non-pintle hitch) trailer with our M1088 that we made into a flat bed so we came up with this hitch design. Just add a drop hitch and you are good to go. Anybody interested in one just let me know. Not sure if it would fit an LMTV though since we don’t have one to mock-up.
TNriverjet
24
Clifton, TN
That looks real nice! Here’s a photo of the back of the M-1083. I bet those Pintles are the same across the FMTV/LMTV platform.
TNriverjet
24
Clifton, TN
Were you able to use the original bolts to mount? Or did you have to source longer ones?
I am interested in one if you are making them. You can PM me cost info.
xomegaiv
Yuma, AZ
The originals were used. But in case some models have different bolts it shouldn’t be hard to source new bolts for it.
Duckworthe
23
San Diego, Ca
Looks good to me, nice and simple. Surprised there isn't a flurry of "can't weld to the frame" replies yet. Or did I just open that Pandora's box?
coachgeo
3,470
North of Cincy OH
Didn't figure that piece it is welded to is considered part of the chassis.... Isn't it more of a rear beefy cross member to attach a pintle too more so than it is a part of the chassis?
Oxyacetylene
179
Stoneville, NC
You could test that piece with a file to see if it is heat treated before welding. That would be the biggest risk I guess of welding to it: annealing the steel and reducing strength? The frame rails are heat treated. I tried cutting a piece of frame with a portable band saw and it just ate the teeth off the blade.
crcarson26
Reno, NV
Uploading OP's photos to the SS server for future reference and archiving...
View attachment 702152View attachment 702153View attachment 702154
This is the exact same direction I am going with my M1088. This is the first rig I've seen to go the flat-bed route on an M1088 chassis for hauling a vehicle. I am contemplating adding a hydraulic dump bed kit on mine to have a tilting ramp for driving my rock buggy onto.
If you have any more pics of this rig, please post them or send them my way!!
Cheers,
