snowtrac nome
- 138
- 63
- western alaska
I talked with my local cat guy today about the over the road 3116 engines. A word of caution he gave me was trash the fuel filter with the rubber plunger on it. He suggested a Racor 6 micron filter,or a cat filter off a c-7 with after treatment. the most problems with the 3116 engines is air in the fuel system which left untouched will cause a host of other problems. The valves only need adjustment once every 80,000 miles but injector replacement will pay like 24 hours. Our engines are what are called high horse power and they can be turned up 20 percent. The duce guys are screwed the sub 215hp engines have less rings and can only be cranked up 10 percent which will equate to minimal gains.
