FMTV ABS Connectors Rot
charlesrg
81
Nj
Most of my ABS connectors are bad like this:
Does anyone have the same problem ?
My research so far led me to the connector specs:
Kostal socket M 24 x 1 3-pin
However this does not seems to be a field crimp connector and I will have to use something like this to redo:
If anyone have made those connectors in the field please share. Otherwise I will have to strip and joint them.
Reworked LMTV
Expedition Campers Limited, LLC
1,558
1,213
TN
Lots like brake cleaner or a solvent may have eaten up that one. I don't see melting. Chinese rubber will do this prematurely as well, as the will deliberately leave out important rubber components to make more $$. UV will eat Chinese rubber in days and colors are often lost.
GeneralDisorder
6,117
Portland, OR
Just cut the rest of that off, clean it up good, use some deoxit, etc. Cut the wires a good bit down from the connector - like 4-6" so you can replace the failed rubber with 3M heat shrink w/sealant and install a Deutsch connector as an intermediate connector in case you do need to do the flying lead replacement cannon plug in the future.
