- 134
- 120
- 43
- Parsons, TN.
Friends,
I'm having problems with my CTIS on a 2.5 ton FMTV. The front tires went down while sitting. I aired them up with an air compressor. When I started the truck all the lights flashed. On one wheel air was leaking around one of the connections. When I shut it down the leaking stopped.
Do these connections have O-rings or some other seal that may be bad, allowing the air to escape?
How do I fix this? Or should I disable the system? How do I disable the system?
Thanks!
Keith
Thanks!
Keith
