agazza2
- 31
- 28
- Ahwatukee, AZ
My truck has started to leak a lot of air when the brakes are pushed. It was coming from the rear of vehicle, so was hard to diagnose just by myself. I used a rod to hold the brakes while I diagnosed where the leak was coming from. The leak was coming out of the exhaust valve on the Tractor Protection Valve which is located directly on the cross member above the rear axle. This is a common problem, but finding a completely new part is a problem as it differs slightly from commercial truck applications.
The original complete Tractor Protection Valve is Midland/Haldex RN50012. Everywhere I checked it was not available due to being marked as Military only.
The rebuild kit part number is Midland/Haldex RN31BC. NAPA lists it online, but my NAPA could not get it, but I found it on FinditParts.com This kit is the most complete one I found, and is only missing one round disc, as the military had one extra section on their tractor protection valve. Order 2 kits for a complete set to rebuild. Here are a few photos of the valve. If you search Haldex KN34101, KN34111, KN34130 ect there are many parts that very close. I think KN34101 would be a direct replacement based on my research but may require one or two adapters for the lines.
