- 821
- 1,651
- 93
- Wauchula, FL
Using the civilian Truck-lite LED Headlight. It also allows for any other civilian headlight to work.
![IMG_6226.jpg IMG_6226.jpg](https://www.steelsoldiers.com/data/attachments/430/430574-913dca1b9179cd8bbd710a674e9855c2.jpg)
![IMG_6227.jpg IMG_6227.jpg](https://www.steelsoldiers.com/data/attachments/430/430575-cbe1b0edb46bb1919604573bb1dfe288.jpg)
Modified an H-4 harness by soldering some military connectors onto it.
First heat the connector and fill with solder.
Then while the solder is still fluid insert stripped wire into connector until its solidified.
![IMG_6223.jpg IMG_6223.jpg](https://www.steelsoldiers.com/data/attachments/430/430572-8a7af3119689b2d5623435080d438c2c.jpg)
Don't forget to put the rubber boots on before you solder it.
![IMG_6225.jpg IMG_6225.jpg](https://www.steelsoldiers.com/data/attachments/430/430577-07066ade64e1033ab941274ae78ba27a.jpg)
![IMG_6228.jpg IMG_6228.jpg](https://www.steelsoldiers.com/data/attachments/430/430582-6d1db15e7da2d3cc9dd2a5dfae5a3633.jpg)
![IMG_6229.jpg IMG_6229.jpg](https://www.steelsoldiers.com/data/attachments/430/430583-fa1bdb54d7122299608429f987dedf72.jpg)
If you can't read the label... 17 top left is High Beam, 18 is top right low beam and 91 is the bottom Ground.
![IMG_6230.jpg IMG_6230.jpg](https://www.steelsoldiers.com/data/attachments/430/430584-bf04dff1f7a6d23f0892e814e9bd7fa3.jpg)
Lights on High Beam and no Flickering without using the anti flicker modules.
![Version 2.jpg Version 2.jpg](https://www.steelsoldiers.com/data/attachments/430/430576-81037d00f9ba4725683ee39725e363b6.jpg)
![IMG_6222.jpg IMG_6222.jpg](https://www.steelsoldiers.com/data/attachments/430/430571-289af9b2c898b84e541753dccbe87fc0.jpg)
![IMG_6224.jpg IMG_6224.jpg](https://www.steelsoldiers.com/data/attachments/430/430573-4a43d00b65254a7fe74abb740a056790.jpg)
![IMG_6231.jpg IMG_6231.jpg](https://www.steelsoldiers.com/data/attachments/430/430586-089b102c24f4562721dd038c460b7aad.jpg)
