FMTV questions
metalman99
Pleasant Prairie, WI
I'm looking for a 5 ton FMTV, M1088 or M1083 and have a few questions.
1. Will HEMTT wheels fit properly, I realize they might be twice the thickness at the mounting holes and can change to longer studs if needed. I want to increase the overall width.
2. Do any of the 5 ton MTV's come with a/c. I have enough Caiman parts to pc. a/c together, but would rather buy a truck with it already in.
Thanks a lot.
blhar15
11
Waterloo, IA
I do not believe the HEMTT wheels will bolt, they are different.
I do not know of any of the MTV's currently being sold at auction that would have A/C. You can add it though with the proper interior HVAC control box, condensor, A/C dryer and A/C compressor, but will take some custom mounting brackets and lines. We have done a couple of these trucks on a M-1078.
XCRV
41
roaming the Southwest USA
I should have typed 2004-2008. Maybe late 2004? I don't know how the smiley face got there.
I've only found eight 2004-2007 MTV cargo trucks sold on GP -- only two of those were M1083. Found twenty-five 2004-2007 M1088s, 18 of which were 2004 from CA. I didn't click on all the 2004s to see if they had AC. Appears that the A1R has a black dash and different instrument panel.
1,178
Look at the bottom of the page just before you hit submit, disable "smileys". The smiley shows instead of an 8 usually.
