- 4,392
- 4,175
- 113
- Brentwood, Calif
Just picked up a 1078 on a trade...couple of questions
diffs, I assume is 80-90 GO, it's a little noisy up front and read a thread about checking levels...other then the main diff housing, where else is it checked?
I see no other access point...unless I'm mistaken.
on the trans bell housing , there is an access panal...mine is missing, held on by 4 bolts...Or is this normal to be not installed?
does tcase take 80-90 GO
what is used in trans? Looks like 15-w40 like the m939 I have.
speedo jumps around...where does the cable terminate into the tcase?
lastly....what are your speeds? I can't get this truck to go over 50mph...and all
the while the CTIS over speed flashes...regardless of speed.
ctis is set to highway.
runs very well all in all...
