This is very state depending. In many states as long as you are not engaging in Interstate commerce then you are not regulated by the DOT regs. That why you see papaw cruising through town in a prevose coach and no CDL is required.Also requires a Cdl. Unless you convert it to an RV first. Truck is 17k, trailer around 5-6k, and and additional 12k for the load. Well within CDL territory of gross combined weight of 26001lbs.
Good to know, WA is very strict. I was under the impression that the commercial motor vehicle safety act of 1986 that unified Cdl requirements applied to all states receiving federal assistance. And even under the fmcsa the modern version continues. But I haven’t read every state code and can only speak to WA code that I have read in depth. Being in law enforcement I was sure to have full understanding of my laws in driving my M1078, so my hobby wouldn’t affect my job. And if you cross state lines, reguardless of state code you are subject to the FMCSA. One cool thing in WA is you can register to a lower weight. So if your truck have a scale weight of 19k and a gvwr of 30k, you can register it lower to 26k and not need a Cdl but are limited in towing to less than 10k. My advice is only worth what you paid for it and recommend the best place to ask if you can tow what you want is to call your local law enforcement commercial motor vehicle division and talk with them. They will cover specific code and what not and let you know.This is very state depending. In many states as long as you are not engaging in Interstate commerce then you are not regulated by the DOT regs. That why you see papaw cruising through town in a prevose coach and no CDL is required. Sent from my iPhone using Tapatalk
