- 10,253
- 6,089
- 113
- Camp Wood/LC, TX
I tackled this today as my belt was OE Cat from 1998. That's runnin' on borrowed time. As usual, this was not a simple task. Yes the fan blade has to come off. If you are familiar with working with fasteners you cannot see, you can unbolt the fan by reaching through the blades. Otherwise, the shroud has to come off, and also the charge air cooler lines. That makes the task much simpler. The belt is also a bit tricky to get over the harmonic balancer. You'll figure it out, but at first I thought it would not go over it. I would suggest you do this PM before the belt shreds and you are doing this on the side of the road. That would suck.
