- 1,299
- 9
- 38
- (near) Xenia, Ohio
When changing out the differential lube in my M35A2 recently, I notice something odd about the oil in the front differential. Keep in mind, the truck had not been driven for over a week when I did the change.
Working forward from the rear-rear diff, the (old) oil that drained was black/brown and smooth in appearance. NO bubbles. Same with the forward-rear differential, black/brown, smooth, no bubbles.
The front differential was a little different. The oil that I drained was not so dark. Almost a brownish green. Now that part I figured was just "newer" (less used) oil that kept its integrity. (The front (steering) axle is an air-select, not a sprag). What I did find odd, was how "frothy" the oil in the front differential was. It was like a foamy drink of some kind. Nothing like the other differentials that I had just drained.
Maybe not something to get concerned about, but I found it odd. Especially after having sat for over a week, and even then, the front axle was never engaged. What could be agitating the oil? I would expect to see the froth if I had drained it after a drive on the axles that were in use. Anyone know differential oil properties and what might cause this?
