Foggy gauges
Privatewrench
19
Kentucky
Does anyone else have gauges that fog up? My generator gauge and air pressure gauges get condensation inside the lense most time I drive it. They work fine and I can still read them, but it's annoying to see. Is there a fix that can help?20190214_123156.jpg
Private Wrench
Jericho
71
Landaff NH
buy new ones! or put them in a box of dessicant and leave them there until they clear. It does work sometimes. ( its the rice and the iPhone trick .but more efficient )
Fatalid
11
Mesa, AZ
I’d say put them in the microwave to dry them out... but my wife tells me people don’t get my sarcasm...
I have had good luck with burying the item in a cake pan full of dry rice, then placing in a warm (not hot) oven for a couple hours or overnight.
SETOYOTA
451
georgia
Every 24 volt military vehicle I’ve owned (and its a bunch) will do this. I’ve never worried about it
sandcobra164
323
Leesburg, GA
If you drive the truck regularly the gauges won't do that. My trucks sit and it's normal for the gauges to fog up after the lights have been on for a while. No Worries as long as you can still read them.
rustystud
3,374
Woodinville, Washington
Does anyone else have gauges that fog up? My generator gauge and air pressure gauges get condensation inside the lense most time I drive it. They work fine and I can still read them, but it's annoying to see. Is there a fix that can help?View attachment 755922
Private Wrench
The only way I know of to keep them clear is to keep the cab warm with a heater. I keep a heater in mine all year long. When the temperature goes below 50 F the heater comes on. It keeps the inside of my cab nice and moisture free including all the gauges.
texas30cal
87
Brenham Tx.
There is damp air trapped inside, you can drill a 1/8” or so hole in back (carefully) to vent it so the dessicant will work even better, then as soon as you remove from dessicant seal the hole with urethane or silicone. If the seal on the gage is bad enough it will may return, if not planning on crossing deep water you can leave the hole open .
cobra5
273
Stevensville, Montana
Common problem because these gauges are sealed and over time the seal deteriorates and allows moisture in behind the glass. You can buy new gauges but they will eventually do the same thing.
