FONTANA scrap yard run #4
bigmike
355
Dixon CA.
Calling all Cali., Ariz., Nev., folks!!! On second thought...calling all interested folks!!!
The date is set. Saturday December 15th.
The gameplan will be the same as the previous 3 runs...
Meet at the Taco Shop just South of the Cherry St. exit off the 10 Fwy. around 11am.
Chow down on some of the best Mexi. food in Riverside County.
Caravan to the scrap yard.
Climb around on all the cool trucks, dig in boxes, crates and containers.
Buy lots of goodies.
Hopefully meet some new folks.
Have a fun day.
bigmike
355
Dixon CA.
groundog said:
:driver: need to get a pto and shift linksge for my winch---hope to be there----Groundog
Do you want me to ask the brothers ahead of time to have the parts ready for you?
groundog
wittmann,az
:) that would be great help---I need the PTO,shift levers and linkage,winch driveshaft for a m-813 5 ton and possible level wind----It depends on money if I can get the level wind now or later Groundog
KaiserM109
SE Aurora, CO
I can't join you (lots of miles between us), but if someone has the opportunity to latch onto a couple of small items and send them to me, it would be appreciated greatly.
I have a '66 Kaiser-Jeep M109 (the one currently in my avatar). The panel on the right side that holds on the head light is mounted to the radiator frame by bolts with a rubber connection between them. I need 3 of them. It looks like that assembly took a whack head on and ripped them apart.
Something else to consider, I have manual steering by Armstrong and would like to convert it. Is there an assembly that can be removed from a scrap truck and bolted on? I have done this on Jeeps, Ford pickups and Broncos quite successfuly and want to do it to this truck. I would like to keep it authentic, if possible, but that is not a hard-fast requirement.
Thanks in advance for your consideration.
Arlyn
bigmike
355
Dixon CA.
Kaiser,
can you post a picture? It would help. They have lots of stripped cabs etc. to root around on.
KaiserM109
SE Aurora, CO
bigmike said:
Kaiser,
I'll try to get a shot of it. It's kinda hard to see if it isn't taken apart; it took me a while to figure out why the panel was loose. I have to go to the storage yard tomorrow, so I'll make sure I take a camera.
JDToumanian
14
Phelan, CA
Napa has stuff like that, in their drawers of "Dorman" hardware. Bring a good one or both halves of a bad one so they can match it up. It's a standard vibration dampening mount.
Cool. I can't think of anything in particular that I need, but I'll probably go there anyway.
Me too. I won't take the day off work, but I'll go if I can (I'll be on-call) just for fun.
Jon
nf6x
Feral Engineer
1,630
50
Riverside, CA, USA
http://www.mcmaster.com/ has those, too, if you don't feel like trekking to the nearest NAPA. Search for "shockmount", and they should show up on the first page. You may need to guess about the rubber stiffness, though.
groundog
wittmann,az
:driver: BIg Mike-were you able to talk to the brothers about the winch parts? hope to pick up parts and head back to Phx sat pm--Groundog
bigmike
355
Dixon CA.
Not yet...I'll try to contact them tomorrow.
