I have owned two Foxes. When running properly, they are a blast to drive around. Great speed and great disc brakes to match. HOWEVER, there are tow huge weaknesses regarding the mechanical design. The Alternator/fan drive system in very prone to failure both of the drive belt and bearings. On operations, the belts were changed WEEKLY by the crews to help prevent failure. It was not always enough. The second major consideration is the gearbox. Less than 300 Foxes were ever built and the transmission is unique to them only. These are weak, and extremely complex. They are also extremely hard to find. Due to the design, it cannot be replaced by anything else, and you will not be repairing it yourself. Lastly, to remove the transmission, virtually everything else has to come out first. I have seen a brand new gearbox destroyed in under 30 minutes by someone using the gear change pedal as a clutch, even though told otherwise.
