I'm looking for comments about the difference in frame height from the front to rear on an M35A3 4x4 project. How much higher is the rear axle from the frame (desired) than the front axle? I've read bobber threads but can't seem to find a comparison. I'm not cutting my frame shorter. I'm using using M105 springs and am in the process of making perches. Wheel base not bobbed, 165".
Right now, if I do as planned with the perch, the rear frame at the axle will be 2 3/4" higher than the front( empty). Is that excessive, about right or not enough? I don't want it to look like it is going down hill and now is the time to make a smaller perch if it's too much. I may use custom 3/4" U bolts, so need to have the height determined before having them made (saddling the spring).
Thanks.
Thanks.
