Frame Height Measurement ona Deuce...
TBigLug
Stockbridge, MI
Can anyone get me a frame height measurement on their M35 at the front axle centered directly over the axle? I'm looking for trucks with either 11.00-20's or even 9.00-20's (I can do the math to refigure for the 11.00-20's).
ems4ty
restricted/ca
Just checked mine.
With 11.00x20's - 32" from bottom of frame to ground at the front axle and 10" from bottom of frame to Top of front axle. Mind you that my front leafs have a slight negative arch so you could add 1" or 2" more inches.
Hope that helps.
-Tyler
TBigLug
Stockbridge, MI
Good point. I'm looking for top of frame rail to ground. I'm working on a bobbed deuce plan is why I'm looking for measure at middle axle.
ems4ty
restricted/ca
With 11.00x20's - 40" from top of Frame rail to ground level (Drivers Side). Measurement taken just behind the front axle. Don't forget to add 1" or 2" due to my leafs having a slight negative arch.
Thanks & Good Luck
-Tyler
