Fried starter x2
KYJoe
Berea Kentucky
I have a 1985 M1009 . very solid truck very basic mil spec. It was driving with no issues but now it keeps frying starters and wires that lead to the starter. Any advice would be appreciated.
Warthog
242
OKC, OK
Do you have the support bracket installed? What type of starter? Direct Drive or Gear Reduction.
What had you changed when the issues started?
KYJoe
Berea Kentucky
Haven't changed anything. The first starter was replaced by the previous owner, the one I just took off is a DB electrical 24v gear reduction starter, same used by the previous owner it started no problem for about 3 weeks before this last one went out.
1,824
What are the symptoms? How long does it take to start the truck when hot? Cold? Need more info. If it's leaking down fuel and you are leaning on it for 4 or 5 minutes, things are going to get hot. Chickens fry, starters fail. Was the last failed starter diagnosed?
KYJoe
Berea Kentucky
Hot and cold it would start right up after the wait light goes out. No leaks that I have found. The starter is dead (tested it) and it smells burnt.
Skinny
495
Portsmouth, NH
Nonsense! You can tune a piano but you can't tune a fish...
Unless you installed two faulty starters I would do some serious voltage drop tests to see if a supply or ground cable is at fault. Anything over .1, maybe .2 volts max is suspect.
rtk
449
Lockport N.Y.
I would also go with some bad grounds , you need good grounding for everything to work properly . I would check and clean all your ground connections . Check for a good ground between the engine and the frame/firewall .
Tow4
671
Orlando, FL
You can get the starter tested at an auto parts store. There is a maximum no-load current spec. If it exceeds that spec, once under load it will draw more amps than the vehicle start circuit (batteries, cables, etc.) can supply.
Skinny
495
Portsmouth, NH
Auto parts store + 24v starter = boom
Probably better off with a shop or atleast find a store with someone that has a pulse. A simple VAT40 would do the trick and most shops have one of those antiques (which still work great) to give you amperage figures. Plus it is real world in the truck data.
KYJoe
Berea Kentucky
Installed the doghead relay, and the new starter. Fired right up. So far so good. Thank you all for the help and great advice it was a huge help.
