JLafer
- 0
- 0
- Waterford, MI
Hey everyone,
So one afternoon i got stuck pretty bad and tried to 4wd it out. 4WD was working but i was stuck just spinning. Tried to 4WD low and creep it out then heard a snap. No 4WD now.![Neutral :neutral: :neutral:](https://www.steelsoldiers.com/images/smilies/icon_neutral.gif)
Since then i have flipped the 4wd air lever and went underneath the truck and spun the shaft and it locks the shaft. tried to turn the flange with a big bar no budge, took the drive shaft off and made sure where the drive shaft mounts to the other flange (PTO) was not snapped and both turned together. they do.
Im wondering what is the most common to break so i don't have to have this torn down for to long. also should i just pull the top of the pumpkin off and see what it looks like? Haven't drained the fluid yet to look for metal chunks, going to do this coming weekend.
Vehicle: 1971 m35a2 bobbed on 52's
Thanks Josh
Thanks Josh
