Front axle seal leak
tatra813
25
Washougal Wa
Drivers side axle is dripping oil from the boot. First is the boot zipper supposed to be on the bottom of the boot?6ocklock position?
What seals do I need to fix this issue and what needs to be taken apart
Thanks for input
considering adding arb air lockers too
cattlerepairman
3,242
NORTH (Canada)
If it is dripping oil from the boot it is **likely** to be the axle shaft seal, rather than the inner or outer hub seal.
Never mind the orientation of the zipper (the boot would just fill with oil). My suggestion is
- get the TM chapters/read threads here so you are familiar with how to do front axle seals. THIS is a good thread: https://www.steelsoldiers.com/showthread.php?8460-Front-axle-seals-and-boots-stepXstep
- think about what else you can easily do while you have the front apart (new-one piece axle boots; I always recommend the slightly oversized ones from rockwelloffroad.com), new king pin bushings
- get the parts that you will need (I always recommend the "sock" type upgraded inner axle shaft seals from rockwelloffroad.com)
- get going.
