Front axles locked
VMS1942
Reeds Spring, MO
I purchased a 1942 Jeep GPW to restore. The front axles are locked, can't push or pull the vehicle. We used a front end loader to lift the front of the jeep while loading on my trailer.
When the front tires are off the ground you can turn the wheels, but they turn opposite of each other. one turns the opposite way of the wheel you are turning.
How do I free up the axles?
Greg
KsM715
142
St George Ks
Disconnect the front driveshaft and see if that makes a difference. Driveshaft disconected and free wheeling axle means something in the transfer case is locked up. with the shaft disc. and the front is still locked but the wheels turn in opposite dir. means your pinion gear is frozen.
1,131
To temporarily free them up in order to move it around, you can remove the front drive flanges.
2,459
As they said...pull the drive shaft. That's very common with these old jeeps.
Just take it apart, clean/lube everything and put it
back together.
We've done several that were "locked up" from setting, haven't had to buy/change out a part yet:-D
Caution...just don't try to force it to roll:shock::shock:
White666
Cheney wa
Ditto what they said, those early front dana's are also bad about breaking off ring gear teeth when they are abused (think spinning in the dirt, then hitting asphalt), that will lockup a diff quicker then sh!t...ask me how I know.
dmetalmiki
2,028
London England
you will be pleased
with a simple and quick fix of that problem..FREE off the (propshaft) external contracting handbrake and you (it) are good to go. common fault that on the MB's.
Kendoe
Phx , Az
You have and open differential for sure , The counter rotating wheels are your spider gears doing what they were disigned to do. Sounds like your transfer case , but it is easier to pull a diff cover to make sure you dont have a ring or pinion tooth wedged in it somehow . If that isn't it I would pull your t-case cover and look at your shift fork and make shure it isn't looked in 4 HI and four low at the same time ask me how I know well my Jeep CJ-7 had this happen last year and would stall if I tried to drive it! I.E. Broken shift fork alowed 4 hi and low to work against one and other . GOOD LUCK Kendoe:deadhorse:
VMS1942
Reeds Spring, MO
I pulled the drive shaft and wheels are still locked. (glad the problem is probably not in the TC)
Today I will pull the differential cover and see what the story is.
I'll post what I find today. Thanks again guys!
VMS1942
Reeds Spring, MO
Sorry, I forgot to post an update, thanks for reminding me.
I pulled the cover and cleaned out all the goop (hardened grease and sludge) What I found is the Pinion Gear is locked. The teeth on the ring and pinion and the spider gears look in good condition. It appears the pinion gear has a frozen bearing.
The holidays have delayed pulling the axles and removing the gear assembly so I can remove the pinion gear. I hope to get back at it next week.
Merry Christmas and Happy New year to all of you.
Greg
4,796
You should be able to remove the drive flanges from the front axle. That should allow you to at least move the truck for now. [thumbzup]
VMS1942
Reeds Spring, MO
That is what I am going to do today. Clinto made the same comment earlier.
I just picked up a driveable 43 Jeep frame and drive train. I am going to build this one first and push the 42 aside for a later build.
Thanks to everybody for your help.
