Front brakes part numbers M1008
hannaganscr
Bode Iowa
I have found that not all K30 part numbers work for m1008 and m1028 so here are some part numbers to save you some time. I had to make 3 trips before I got the right parts
Front Rotors
Issue if you get the wrong part Wheel stud holes are 15mm on the wrong part
the Right part has 17.4mm Wheel stud holes.
Advance Auto parts... PN PNYH141469
Orielly Auto parts... PN 5048RGS
PADS
Advance Auto Parts... PN FLD149
Orielly Auto Parts...PN SM149
hannaganscr
Bode Iowa
FINALLY GOT IT FIXED!!!! No more death wobble. It was warped rotors and a brake caliper hanging. The guy before me that had the truck put all new front end parts in it tie rod ends all bushings including leaf spring bushings and alignment had steering stabilizer shock replaced and had steering box checked out. I put kinpin bushings in and a new steering stabilizer. The problem was still there. I got the tires off and rotors looked great and new pads so I didn't question the brakes. Miced the rotors and found out rotors were warped and also one caliper hanging. The truck didn't wobble all the time and I didn't feel any pulse in the brake pedal. So happy now I got it fixed.
Warthog
231
OKC, OK
Why not get the GM part number from the TM 9-2320-289-34p parts manual? Most stores can cross reference that number easily.
Figure 120, item #2 and 10.
gmjunky87
halifax, pa
Drock, Thank You, I just ordered an 18FR652. I have come to find that the SRW and DRW pick ups and supposedly the 2wd trucks used the same calipers for 1 ton and above. I did cross reference the part number in the TM 14002543, the only calipers I could find were from Bendix, Wagner and Cardone at the time couldn't find the ac delco part number. Also it didn't cross reference with GM parts website. I just wanted to ask if anyone had any luck finding a part number that didn't cross reference with the TM part number.
