Front differential additive?
GM72K10
61
Bucks County, Pa.
In reading the LO 9-2320-289-12 Lubrication order, it seems like you're to put the additive in the front diff. if its a M1031, am I reading this right? I just put it in the rear diff. of my M1028a1s (M1031s).
thanks
ida34
32
Dexter, MI
I think you mean the limited slip additive. If you have a limited slip in the front then you need it. A lot of premium gear lube already contains the additive. Check the bottle to be sure.
tsmall07
Springfield, VA
The additive can also be called a "friction modifier". Get the stuff that already has it included because the separate tubes are a pain to add.
sweetk30
horseheads,ny 14845
but what if you have a civilian issue truck with gov locker? should you use the additive?
i am swaping in a power lock in my 60 frt and need to get the additive. but have a new gov-loc in the rear and want to be safe. do i need it?
AJMBLAZER
Paducah, KY
The Gov-Lock needs the GM limited slip additive.
I've actually heard Ford and Dodge guys recommend the GM additive as a really good product to use in those manufacturer's limited slip diffs. Apparently it's good stuff.
