thompsoncustom
- 61
- 18
- iowa
Hey guys was wondering if anyone else has ran into this issue. My humvee is a 1097r with 6.5/4 speed and the front end seems to hop/wobble between 30-35mph but is perfect at all other speeds. Thought it might be my tires so I rebalanced them with weights twice and it didn't help, so I ended up fluid balancing them but the front end bobbing is still there but runs smooth as silk at 70mph on the interstate and all other speeds.
I did find there is a little play in the pitman arm but you can't feel the wobble in the wheel at all so I don't think that is it and couldn't find anything else loose or have any play like the axles but you can see the hood moving at the above problem speed.
