SasquatchSanta
- 18
- 0
- Northern Minnesota
Does anyone know if there is a goblin that hangs out around the front freeze plug on the LDT & LDS Multis?
To date I've had three freeze plug block heaters quit working that were all mounted in the front plug area.
I originally thought the first one (which was new) went out because I started the engine with the heater plugged it. I've been told conflicting stories. Some say starting a motor with a heater plugged it will short it out because of air bubbles --- other say that't hog wash.
Anyway, I replaced the first unit only to have it last a few weeks and also go out. When we installed the new LDS engine I mounted heaters in both the front and rear freeze plug locations and now, once again, the front unit has quit working. The rear one still cooks away but the front one it cold.
When I installed the units the engine was out so it was easy to see that they weren't toucing the side of the block. The heaters I'm using are 650 watt units and are the only ones I know of that will fit. I'd like to have heaters front and rear because I think having two versus one big 1,200 watt unit heats more evenly.
Anybody got any ideas --- perhaps sme goblin repellent?
