- 9,576
- 211
- 63
- Dickson,TN
I tore down the passenger side of the front axle today to replace a leaking axle seal and boot. As I was cleaning the tons of grease off of everything I noticed a little movement in the u-joint. It's just a little that you barely can feel. Everything moves freely. Do I need to replace the joint or is a little slack ok?
If I have to replace it is there a Napa number or is it strickly military? I looked in the parts cross-reference and didn't find a cross.
On the axle boot the TM says to use cement on the zipper. I don't have any "military cement" so I'm assuming RTV silicone will work?
