Front U Joint replacement
Big Dale
Ohio
I just recently got a Six Inch lift put on my m1009, while it was on the lift, the mechanic told me my front u joint on the driver's side was bad. I did a search and couldn't find anything, how do you replace the U joint?
Oldsouthernboy
Jacksonville, al
First you need a good supply of fowl lauage, You have to pull the, whole hub, after taking off the warn hubs, removing the bearings, brake caliper and supporting it , remove the backing plate and pulling the axle. (See TM) then you can remove the U joint, with mutiple cuss words if a old u joint, then install the new u joint. While you have it apart go ahead and inspect the bearings, races and replace the grease seal. Check your hub and brake pads, if in worn condition replace with new. Then repeat with opposite side. If one u joint is bad you had better plan on replacing the other side soon also.
Westech
CPL
6,104
208
cow farts, Wisconsin
EVERYSINGLE CUCV I have owned needed the u joints replaced. Even if there is no play in them I will bet anyone with stock u joints that there junk. They rust up and become very hard to move and you can brake a axl just due to a stuck u joint. If you have not replaced your u joints or they have never been replaced I will bet you there bad.
1,178
If you have no mechanical skills or experience(since you have just posted this question), simply pull in to a repair facility, hand them your key and tell them what you need. Sit and wait, pay. Drive home happy and clean.
edit, oh boy, I just noticed Westy was reading this thread, as I was posting. Duck!
Westech
CPL
6,104
208
If this is the way you think how a U joint is changed::deadhorse: Better just take it to the Local hack shop like Dh said.
85 year ASE Master Mechanic/Technician
Love Westy
motormayhem
Tucson, AZ
Not as bad as it sounds I just did bearings, new axleshaft, and the inner axle shaft seals on mym1009's D44 which is practically a 10 bolt. The u-joint could probably be done in 2-3 hours without much difficulty. Now inner axle shaft seals...thats fun aua
skateabrock
anchorage, alaska
not to bad. you are going to have quite a variety of new u-joints that you can buy and install. be sure not to buy cheap schucks ujoints, DANA/SPICER is the way to go, non-grease-able is stronger, but i guarantee that is what you have and if you could have greased them then they would have lasted longer. Its all preference, but I buy the spicer grease-able u joints and maintain them. Never had a prob. ****, you could go buy some ctm's and never worry about them again.
cucvrus
10,427
Jonestown Pennsylvania
They may be. The would be a minor modification in comparison to what I seen and heard done to these poor CUCV's. Probably the yokes are worn out and the caps were spinning in the yokes from running a seized U joint at one time. Time to get the driveshaft re-yoked at a drive line dealer. Good Luck. But if ain't broke don't fix it. Prepare for the day when it needs fixed by getting a new driveshaft made of finding a good used one. On the M1009 it needs the C clips on the cap to axle yoke to keep the U joint centered.
nyoffroad
687
Rochester NY
Why does it look like the U-joints are welded in on my m1008?
I've seen that before, some hack changed out the joint and couldn't get the C clip back in so out came the MIG. Find a used replacement or have the shaft rebuilt, rebuilding isn't that expensive.
cucvrus
10,427
I have a few fronts and rears. They will be up for sale soon. I am having a sit down and relax sale and selling everything. Soon. But California. Can do. Have a Great Day. 3 More M1009's and that's it. Done. Final Editions.
nyoffroad
687
Rochester NY
Are you retiring from CUCV's? Or getting to be like me and just plain tired?
cucvrus
10,427
Both. But I have other interests and I like change hobbies every once in a while. I am bored with this one. I have lots of projects that need finished and am looking forward to getting them done. I have some nice automotive art deco I am going to do and add to my barn. I am collecting things all the time and will be putting a lot of time, effort and money into a few properties. I am about to order a new pick up again and want to clear out some old vehicles and parts. I am saving my best 1984 M1009 for last. Have a Great Day.
