ChuckM
- 0
- 0
- Brantley, AL
I was reviewing the tm9-3830-501 for winch maintenance and see the front winch has a capacity of 9,500 lbs (page 1- 8 ). Is this correct? For some reason I thought they were rated for 20,000 lbs.
It's 100% mechanical. If the winch slows down, the engine slows down too or something breaks. FWIW I've done lots and lots of winching. I've never set the idle above 1000 and I've never ran out of power and bogged the engine. I have broken shear pins.it slows down when you load it to its limit. The spec in the TM states "at 15 feet per minute".
