- 164
- 454
- 63
- Jefferson, Massachusetts
While draining my Spicer 5 Speed the oil came out frothy. Is this normal?
I had just done a short run, ran through the gears with the transfer case in neutral then drained the oil preparatory to a diesel flush. The oil also started draining from the filler port first. I checked for water with Gasoila which was negative.
Backstory, 8 months ago I mixed an 80/90 GL4 with what I assumed was the original 80/90 GL1 and the transmission did not like it. Ran through the gears fine for the first half mile then lost all power in all but first and barely creeped home. After a fruitless search for an 80/90 GL1, I settled for a 90W GL1 to refill after draining. After this everything seemed to be fine, but just to be sure I wanted to do a diesel flush.
