Frustrating Acceleration Problem
eaglevets
Augusta, GA
I have an otherwise great-running MUTT. At times she will lose power when accelerating. Usually happens above 40 mph. As you give it gas, it chokes and coughs and tries to shut down. Ease back the gas to 30 to 35, and it chugs along. This is an intermittent problem, but is quite troubling, since it can happen anywhere without warning (usually on an incline). We cleaned the gas tank and fuel lines and insulated the lines (thinking a vapor problem). Put in a new fuel pump (the Chevy conversion), but still don't have a solution. What say you? Ever had this problem?
101coolcars
San Luis, colorado
I've had mica in the fuel system "filter" that cause problems like your having. The little platelets pack up against the filter but then lay back down allowing flow from time to time. I think the mica comes from contaiminated fuel stations especially in the mountains or rural areas.
uriss
French Settlement,La.
For all my vehicles I have put inline a regular boat water separating fuel filter. Readily available as a kit from Wal-marts for around twenty dollars. Live right on the river and I drive older vehicles with crud in the tanks. Spin a filter off and spin a fresh one on. Takes care of my problems all the time.
m38inmaine
103
Maine USA
The M151 is famous for a flat spot in the carb, the TM shows pulling the choke out until it smooth's out then loosen the cable clamp on the carb, push the choke cable back in and re tighten the clamp screw. There is a company in Florida called Brooks Engine Service that fixes this problem, they advertise is MVM.
eaglevets
Augusta, GA
Some great feedback - thanks, all. A friend uses AVGAS in his - contains lead, not ethanol. He says that gets rid of a lot of the problem for him.
nattieleather
148
Cleveland, OH
I would always run my M151 on the hi octane gas 93 or better if I could find it so the Avgas would be the same thing. If I put the old 87 octane in I would have the problems you are talking about.
Bill Nutting
1,370
Chesterfield, Mi.
Oh boy did we have this problem! First off, get your carb " rebuilt" by Brooks Engin Service. Then try to improve your fuel. We mix a gallon or two of racing fuel to a tank of the junk they sell as "gasoline" these days. These old vehicles just don't run right on alcohol. This stuff boils at a lower temp than real gasoline causing vapor lock. You may also try a "lead additive" in your gas. I have been running my M37 on modern fuel for 11 years. In the last two years I have been having vapor lock issues. Adding a little racing fuel fixes it for me. Our M151 runs a lot better since we had Brooks do the carb. It runs like a top with the chock wide open. Down side to racing fuel is it costs $8.00 per gal. It's the same gas we used to buy for 25 cents a gal. in the 60's...
eaglevets
Augusta, GA
Well, we put a new carb in it and it runs good. Except, now it is slow to start. The starter turns for a good 60 second plus, before there is fire in the hole. Thoughts?
eaglevets
Augusta, GA
We're not through with this yet. Still starting issues. Replaced plugs and batteries. Replaced coil (twice). Cleaned out distributor and contacts. The starter turns with much vigor, but the system won't fire for a good minute of turning episodes, it it fires at all. So frustrating, especially since we took care of the fuel starvation issues with all of your help. Anyone got some new thoughts?
Snoop
Germany
Hello from Germany,
I had the same problems with my M151 A2!
Engine lost power above 40mph.
I removed the small metal-fuelfilter in front of the carb. and cleaned it with compressed air.
After that the MUTT droves like new.
Meanwhile I replaced the old fuelfilter.
Bye
Snoop
