Hasdrubal
- 4
- 0
- Vancouver BC
Putting in a new fuel lift pump, which only lasted 5 years. I decided to replace the fuel filter housing assembly at the same time. Tomorrow I"m going to bleed the system using compressed air via the fuel tank. I know how to bleed the filter. Question is, I have now allowed some air into the line that goes from the filter assembly to the IP. After bleeding filter, should I just start it and hope she clears up or disconnect the pink wire to the IP and crank her for a while so that the air in the line compresses somewhat, or crank her until the air hopefully passes the IP. Not sure about it. Any input would be appreciated
