- 153
- 232
- 43
- wimberley texas
I have a friend who has a 805B set, the actual fuel tank drain that protrudes thru the skid frame rail is or was leaking, he drained the tank and set out to find a bung or plug where when its tightened it will swell up and seal the tank from draining, no Auto Parts store offered a read fix so in his wisdom he bought the closest size and overdrilled the tank wall to where this new stop or filler plug would fit and seal off the tank, never mind he took away the tank draining feature, well we know where this is going, the material the new plug is made from lasted a few weeks and then deteriorated because it was made for water and not DIESEL fuel, to the point now the tank is leaking pretty badly.. I'm sorta out of suggestions to offer him on what or how he can seal the hole and or if or where we can buy a real diesel rated plug ..
All suggestions welcomed and maybe i can help him get this solved..
Thanks again, mac/mc
