dagsurplus
- 0
- 0
- Fresno, CA
I started my new-to-me M1009 from GL; fired right up. Then found a pool of diesel on ground under bell housing. "Valley" under intake manifold wet with fuel but could not find source of dripping. After searching this great site, assumed it was bad throttle shaft and/or IP seals. In the multiple times I've started the engine in the past 3 hrs, I noticed that the dripping slowed and now has stopped, at least the dripping on the ground. I have two questions:
1) Could it be that the throttle shaft/IP seals had dried in the 2-3 yrs it sat (all fluids were drained) and have now rehydrated and thus, sealed? If so, other than watching for future leaking and putting the IP rebuild on the to-do list, is the truck drivable?
2) Is it dangerous to drive with a possible fuel leak on top of the engine?
Thanks in advance.
Thanks in advance.
