The one By the fuse box is a Mopar part that was put on at dodge, they can also be found on some of the civilian trucks.
( I think the ones that came with a towing package, to help protect that circuit with the extra lights on the trailers)
The one by the brake release ( horn relay ) was part of the blackout light kit that was usually installed at the depot or unit level. Your truck might not have had the Blackout lights installed, or if it was, PVT Smuck might have mounted it in a difrent location.So it is no big deal if it is not there.
Also, Just so you know, these relays need to be grounded threw their case. if having trouble with a circuit that they control. you might want to make sure they are grounded good where they mount to the dash
( by sanding any rust or paint off between the case and the dash )
Come to think of it, you might want to check to see if your Dash itself is getting a good ground, This might also explain why your gages do not work, because they are also grounded threw the metal portion of the dash....
Also, I Just re read your first post, the electrical system on these these trucks are 12 volt so a 12v battery is correct.
good luck, Merry Christmas and keep us posted !
