sermis
- 17
- 38
- Temple, TX
I noticed that my truck was getting hard to start. Full peddle and it would barley run until it warmed a bit then it was better. I moved it out of the way and was letting it idle for a bit and noticed fuel / oil all over the motor and on puddle on the ground. Opened the hood and had a stream straight up from on top of the fuel filter base. I then noticed that the top of the fuel filter base cracked about 1 1/2" just inside of where the gasket would be on the under side. Any reason it would crack there?
Anybody have a good take off filter base they can send me.
I knew I should not have sold my parts motor.
