fuel filter diameter
joshua180422
Hawley PA
I am trying to buy a 12 volt fuel filter warmer for my deuce. I am home on leave and not around my truck so I can not measure it. Can any one tell me the diameter of the stock fuel filter canister? Thanks for any help. Also I did search plenty and did not find anything,
1,171
For which housing? there are 3 of them. 1 primary and 2 secondary filter housings.
Unless you have alot of water in your fuel, you should not need to heat them. The fuel heats as the truck runs(from recirculation).
Drain your filter housings and it water should not be a problem, ever,
1,171
I don't think it will help.
I cut my alternate fuel usage in the cold months. A50/50 mix should work well, even well below freezing.
1,171
He needs the canister OD, not the filter diameter.
DeucesWild11
12
Putnam County, NY
It's definitely larger than 2 7/8".. ha ha.. sorry I just went by the post headline.. what do I know.. it took me an manual to find out where the master cylinder was..:?
