- 1,876
- 1,440
- 113
- Laramie County, Wyoming
Been playing around in the Toads engine compartment and I noticed fluid leaking down the fire wall below the heater hose. I looked underneath and sure enough a small puddle. I tightened the clamp to the heater and leak went away, or so I thought. In addition to the AF dripping, fuel is coming out of the drain line. Not from the outside, from the inside. I checked the vent on top, nice and tight, Checked the drain fixture, same thing, nice and tight. It only drips when the engine is running and then for a couple of minutes after the engine shuts down.
Internal failure of the filter or fuel filter housing? I did notice that both the drain fitting and the vent fitting were missing their O rings. Not sure if that's a factore since there isn't any fuel coming from the outside of the fittings. Only down the drain line.
Any ideas?
In the attached PDF, its Items 4 (all there), 5 (2 each missing), 6, (its there too), and 14 (also there) fuel is draining down line number 24.
Any ideas?
