Fuel Filter Mod
NEIOWA
124
NE IOWA
From my experience doing the same. Can buy over the counter filters ar any NAPA etc. Easy to prime (will start and run),
joesco
Hampstead, NH
If and when I get him running I will let you know. But I did it for several reasons, ease of maintenance, better
filtration, filters available most everywhere and no worry about leaking gaskets. I also purchased Speddmon's spin-on
oil filter adapter / filter setup also. Did the same when I refurb'd my Deuce.
cuad4u
88
St Matthews, SC
I bought several 002A and 003A generators that were missing the original 3 section military canister type fuel filter assemblies. I bought several two section Ford tractor fuel filter assemblies off ebay for around $30 each. It mounts exactly as shown. The first section is a water separator with see-through GLASS bowl and the second section uses a standard NAPA pleated paper fuel filter. The filter assembly I used does not use spin on filters. It uses the cartridge type filter elements. I think filter changes will be MUCH easier and less messy with the set up shown, but what I did has worked well for several years.
