m715
- 16
- 18
- western ma.
I found a 30 thousand btu heater, same heater on m35a1 and other equipment. What is different is this has a fuel tank on top with a fuel pump and fuel filter mounted. Has a control start box the same as on trucks. So basically it is a self contained heater with a vertical bracket to mount on a flat surface. I thought this would work nicely for a shelter/ camper I have. I don't see any info on the heater other than what's on the burner unit. Anyone know if this set up has its own nsn or what its used on?
