Fuel Gauge bottoms out
bartmech88
Spring, Tx
All right need some help. I was messing around under the dash. Now every time I turn on the headlights the fuel gauge goes to empty. Has anybody come across this? And if so do you have a fix?
rchalmers3
30
Irmo, South Carolina
Might be easy. If it were me I'd go back under the dash, wiggle and seat the plugs on the dash gauge connections.
My guess is you have lost a sure ground path to the instrument panel. The current demands of the instrument illumination lights are now finding a secondary ground path through the fuel tank gauge.
Rick
Rick
soule64
Huntsville, AL
I had the exact same thing happen on my M1008 - ended up being a bad ground. Check all of the grounds in the headlight circuit and under the dash (clean to bare metal & reset), especially the headlight switch as the shell of the switch grounds itself to the dash. I did it all at once so I don't know the exact culprit, but everything works now. Hope this helps.
Warthog
232
OKC, OK
More than likely it is the ground wire connection next to the parking brake. It is where the 6 legged connector is. The connection provides the ground for the entire instrument cluster and associated items.
Remove, clean and reinstall.
