fuel gauge dysfunction
100acre
Bonners Ferry, Idaho
My fuel gauge has been stuck on full even when close to empty so I installed a new sender in my m1008 and fuel gauge still says its got a full tank.I tested the sender, its fine.the wire going to the sender had a pigtail connector which was loose and now rigged to fit. . Had some issues with the hot wire.The ground is grounded. According to the multi-meter it says the gauge is bad. where can I buy a new printed circuit board (looks coroded) and gauge or am I doing something wrong?
Asgar
Wallingford, CT
Just to be sure... do you have a very good ground at the fuel tank? Like to the frame with a star washer and connected to good metal on the tank fuel pick up? If not so sure, you could put an aligator clip on the metal fuel pipe on the pickup and connect to a good ground to troubleshoot this.
For what it is worth, my M1008 reads beyond full when full, drops to half at 13-15 gals, then to E when there are 7-10 gallons left in the tank. It is very consistent but not accurate.
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
All military fuel gauges are made using old arcane magic, to fuze the souls of dead politicians and lawyers to the gauge.
know how I know this? they all LIE!
100acre
I was thinking the ground could be better I like the star washer idea thanks
100acre
pigtails
The hot wire pigtail connector (female) plug that connects to the fuel sender was broke off nearly at the point of no return I've just barely been able to rerig it but I'd like to get another. Any ideas where I may find something like that ? LMC does not have anything in their catalog
Tanks
