fuel gear pump
spencer p
ellinwood, ks.
I need to remove the gear pump on the injection pump (the one that boosts pressure) and put a new gasket behind it, it appears to be leaking, there are 4 screws and two bolts- if i remove the two bolts will the whole assembly clear the steering box ? I already removed the shut off cover to make a gasket, now is the time. also any suprises ?
