Fuel injection line ID
bones1
Southern Maryland
I was looking around to see where the engine leaks are all coming from tonight and I found this plastic line behind where you would turn up the fuel. It is kinked closed and just goes in a loop to the other side of the brass fitting?
The truck runs fine, I don't know what this hose does. I do know it shouldn't be kinked closed like that. I think.
Also, looking at the threads on the fuel adjustment screw, do you think it is turned up a little?. Runs real good.
JDToumanian
14
Phelan, CA
Looks like your FDC is bypassed.... You could take those fittings out and put pipe plugs in there if the kinked hose is a little too cheesy for you...
Jon
bones1
Southern Maryland
Never checked boost or EGT #s but think I might get some gauges , actually looked at some Westach gauges this morning. Fuel tank says diesel only.That should have been a clue.
