Fuel injector pumps
peace94
Santa Fe Texas
Does anyone know if you can use a 6.2L desiel civi injector pump on a 1009. Because I was just going to go to a salvage yard to try and find a working 6.2L injector pump to get my 1009 going, while I can save up to get a new or rebuilt one.
Its getting sad seeing her just parked in that one spot in the driveway like that. She needs to be one the road so everybody can see her.
Thanks in advance.
burbn10
Lake Villa, IL
Yes you can use civilian IPs. They are just usually tuned to less power unless you find one from a 1-ton J-Code. They work the same though as far as I know.
jdemaris
The pumps are all basically the same for 6.2s. C-code has less max fuel delivery setting and . . . if from an automatic (700R4 and 4L60) - will have a TPS switch attached to the throttle that your truck won't use. That TPS contols converter lock-up and some emissions controls. If from a J-code automatic (T400 and 3L80) it will have a VRV attached to the pump throttle to control vacuum to the trans modulator (vacuum regulator valve).
Also maybe half the mititary pumps had a thin-fuel kit added in an attempt to make them last longer when run on JP8 military fuel.
burbn10
Lake Villa, IL
He is just outside Union Grove, WI. Badger Diesel. My truck has ran like a champ using the rebuilt pump and injectors from him. Been about 6 months now.
